OpenBCI_GUI /// Blank screen
Good night everybody.
I installed the OpenBCI_GUI some days ago and it use to work perfectly with bluetooth conection and the ganglion board (in Linux Mint)
However today I try to open the GUI and it keeps in gray tone. This is the text in the terminal.
sudo ./OpenBCI_GUI
Screen Resolution: 1920 X 1080
For more information about how to work with this code base, please visit: http://docs.openbci.com/OpenBCI Software/
RunnableTask.run(): A caught exception occured on thread main-Display-.x11_:0-1-EDT-1: RunnableTask[enqueued true[executed false, flushed false], tTotal 0 ms, tExec 0 ms, tQueue 0 ms, attachment null, throwable java.lang.RuntimeException: Waited 5000ms for: <287eaf8a, 26b954f5>[count 2, qsz 0, owner <main-FPSAWTAnimator#00-Timer0>] - <main-Display-.x11_:0-1-EDT-1>]
java.lang.RuntimeException: Waited 5000ms for: <287eaf8a, 26b954f5>[count 2, qsz 1, owner <main-FPSAWTAnimator#00-Timer0>] - <main-FPSAWTAnimator#00-Timer0-FPSAWTAnimator#00-Timer1>
at processing.opengl.PSurfaceJOGL$2.run(PSurfaceJOGL.java:410)
at java.lang.Thread.run(Thread.java:748)
at jogamp.common.util.locks.RecursiveLockImpl01Unfairish.lock(RecursiveLockImpl01Unfairish.java:198)
at jogamp.newt.WindowImpl$ResizableAction.run(WindowImpl.java:2118)
at jogamp.newt.DisplayImpl.runOnEDTIfAvail(DisplayImpl.java:450)
at jogamp.newt.WindowImpl.runOnEDTIfAvail(WindowImpl.java:2782)
at jogamp.newt.WindowImpl.setResizable(WindowImpl.java:2154)
at com.jogamp.newt.opengl.GLWindow.setResizable(GLWindow.java:370)
at processing.opengl.PSurfaceJOGL$5.run(PSurfaceJOGL.java:452)
at com.jogamp.common.util.RunnableTask.run(RunnableTask.java:127)
at jogamp.newt.DefaultEDTUtil$NEDT.run(DefaultEDTUtil.java:375)
DefaultEDT.run(): Caught exception occured on thread main-Display-.x11_:0-1-EDT-1: RunnableTask[enqueued false[executed true, flushed false], tTotal 5247 ms, tExec 5247 ms, tQueue 0 ms, attachment null, throwable java.lang.RuntimeException: Waited 5000ms for: <287eaf8a, 26b954f5>[count 2, qsz 0, owner <main-FPSAWTAnimator#00-Timer0>] - <main-Display-.x11_:0-1-EDT-1>]
Local Version: 402, Latest Version: 402
GUI is up to date!
Graphics & GUI Library: ControlP5 2.2.6 infos, comments, questions at http://www.sojamo.de/libraries/controlP5
attempting to load images for presentation...
DONE loading images!
So I run the next commands:
I hope this can be useful for others facing a similar problem.
