How to create FFT plot ?
I use cyton board and I use a code to display in real time the eeg data that I get. I would like to display fft plot at the same time.
How should I do it ? Are there already codes that allow to do?
Thank you,
Regards
    RT, hi.
    Each programming language generally has a library of DSP, Digital Signal Processing routines, that can perform filtering and FFT operations. Just do a Google Search on your programming language name and DSP. There are also libraries for plotting bar graphs and such.
