waited 5000ms error in openbci cyton connection with gui
my unit is cyton open bci and conneded dongle to pc(64 bit window 7) after runing processor 3.4 getting waited for 5000ms error ang GUI shows blank screen.
    Is this a new Cyton just purchased? Have you tried connecting to it from other laptops?
    Sometimes when the GUI shows a completely blank / black screen, it means your OpenGL (graphics drivers) from the laptop manufacturer are out of date. What is your definition of "shows a blank screen"?
    Does the COM port show up in your Device Manager when you plug in the dongle? Conversely it should disappear when removed.
  • Version Open BCI GUI 3.4 and OpenBCI_GUI 4.02
    in program file after openBCI_GUI.exe
    Com port display but got Failure communication time out
    device failed to open host poll
    After processing3.4 set up
    select c:\user\name\mydocument\processing\openBCI_GUI\ openBCI_GUI\
    openBCI_GUI.pde display openBCI_GUI but after running it shows waited 5000ms…..
    error and GUI screen is blank
    _____________________________________-
    When I try this procedure first
    time I got waveform after connecting electrode, So its may not be driver issue; but now when I install new
    version GUI 4.02 its not work so I again tried older version 3.4 and used HUB respectively
    still both are not working.
    In other PC windows 10 and 64 bit configuration I down load
    all software and I got output for older version after few days openBCI_GUI
    folder is deleted from processing folder
  • it is new board cyton 32 and purchased just 15 days before.I used window7, 64bit laptop. kindly consider this details in above description
