ImportError: No module named yapsy.PluginManager
I am using OpenBCI - Python in my Ubuntu 18.04
I tried to run the below code for communicating the device through terminal
sudo python user.py -p /dev/ttyUSB0
But it shows the error -
> Traceback (most recent call last):
> File "user.py", line 12, in <module>
> from yapsy.PluginManager import PluginManager
I tried to install yapsy after that also the same error is showing. If I use the code without sudo, then it shows like
> serial.serialutil.SerialException: [Errno 13] could not open port /dev/ttyUSB0: [Errno 13] Permission denied: '/dev/ttyUSB0'
Thats why I used the sudo command.
Kindly help me in solving this error and to run the module using python
