No signals EEG, DIY-Cyton 8ch
Hello dear!
I am new to neural interfaces
I collected the Cyton board from github, programmed it via pickit3, updated OpenBCI v3.1.2
I tried different versions of OpenBCI_GUI, OpenVIBE, but there are no signals from ADS1299.
I could not find RF22301-2, I used a UART master-slave from HC-05 (115200). Tried and wired UART, the firmware is loaded.
But there are no signals, sometimes a short signal skips.
I checked the chips on the TI ads1299 evaluation board and HackEEG Shield, they are working.
Serial(command ?):
Board ADS Registers
ADS_ID, 00, 3E, 0, 0, 1, 1, 1, 1, 1, 0
CONFIG1, 01, 96, 1, 0, 0, 1, 0, 1, 1, 0
CONFIG2, 02, C0, 1, 1, 0, 0, 0, 0, 0, 0
CONFIG3, 03, EC, 1, 1, 1, 0, 1, 1, 0, 0
LOFF, 04, 02, 0, 0, 0, 0, 0, 0, 1, 0
CH1SET, 05, 68, 0, 1, 1, 0, 1, 0, 0, 0
CH2SET, 06, 68, 0, 1, 1, 0, 1, 0, 0, 0
CH3SET, 07, 68, 0, 1, 1, 0, 1, 0, 0, 0
CH4SET, 08, 68, 0, 1, 1, 0, 1, 0, 0, 0
CH5SET, 09, 68, 0, 1, 1, 0, 1, 0, 0, 0
CH6SET, 0A, 68, 0, 1, 1, 0, 1, 0, 0, 0
CH7SET, 0B, 68, 0, 1, 1, 0, 1, 0, 0, 0
CH8SET, 0C, 68, 0, 1, 1, 0, 1, 0, 0, 0
BIAS_SENSP, 0D, FF, 1, 1, 1, 1, 1, 1, 1, 1
BIAS_SENSN, 0E, FF, 1, 1, 1, 1, 1, 1, 1, 1
LOFF_SENSP, 0F, 00, 0, 0, 0, 0, 0, 0, 0, 0
LOFF_SENSN, 10, 00, 0, 0, 0, 0, 0, 0, 0, 0
LOFF_FLIP, 11, 00, 0, 0, 0, 0, 0, 0, 0, 0
LOFF_STATP, 12, 00, 0, 0, 0, 0, 0, 0, 0, 0
LOFF_STATN, 13, 00, 0, 0, 0, 0, 0, 0, 0, 0
GPIO, 14, 0F, 0, 0, 0, 0, 1, 1, 1, 1
MISC1, 15, 00, 0, 0, 0, 0, 0, 0, 0, 0
MISC2, 16, 00, 0, 0, 0, 0, 0, 0, 0, 0
CONFIG4, 17, 00, 0, 0, 0, 0, 0, 0, 0, 0
LIS3DH Registers
0x07 00
0x08 00
0x09 00
0x0A 00
0x0B 00
0x0C 00
0x0D 00
0x0E 00
0x0F 33
0x1F 00
0x20 08
0x21 00
0x22 00
0x23 18
0x24 00
0x25 00
0x26 00
0x27 00
0x28 00
0x29 00
0x2A 00
0x2B 00
0x2C 00
0x2D 00
0x2E 00
0x2F 20
0x30 00
0x31 00
0x32 00
0x33 00
0x38 00
0x39 00
0x3A 00
0x3B 00
0x3C 00
0x3D 00
Python:
Connecting to V3 at port /dev/ttyUSB0
Serial established...
OpenBCI V3 8-16 channel
LIS3DH Device ID: 0x33
Firmware: v3.1.2
No daisy:
(8, 'EEG channels and', 3, 'AUX channels at', 250.0, 'Hz.')
------------PLUGINS--------------
Found plugins:
--------------INFO---------------
User serial interface enabled...
View command map at http://docs.openbci.com.
Type /start to run (/startimp for impedance
checking, if supported) -- and /stop
before issuing new commands afterwards.
Type /exit to exit.
Board outputs are automatically printed as:
% <tab> message
$$$ signals end of message
-------------BEGIN---------------
--> /start
No function loaded
% OpenBCI V3 8-16 channel
% On Board ADS1299 Device ID: 0x3E
% LIS3DH Device ID: 0x33
% Firmware: v3.1.2
$$$updating channel settings to default$$$
