networking widget in OpenBCI_GUI with WiFi Shield, UDP, fails.
Hi
I have been trying the use the Networking Widget in the GUI while steaming from WiFi (at 1000Hz).
The GUI is able to stream and display data on the TimeSeries and FFT widget.
However the Networking widget under the settings below is unable to send data to my java client.
The client program is a Java program which receives UDP data on localhost and on the same port.
Settings are as follows: Networking Widget: UDP, Stream1, TimeSeries, IP: 127.0.0.1, Port: 12345, Filter: ON
I am successful with the same settings (as given above) when I use the bluetooth dongle.
When using WiFi - I received no such data
When using BT Dongle - data is received.
Is this by design or is there a bug?
Cheers
Abheek
