I'm not sure I understand your question. After processing the raw data with a high pass filter (at around .5 hz), you will end up with EEG data that ranges from say approximately plus and minus 100 microvolts. This is the normal range of EEG data values and represents the differential voltage measured between the channel electrode and reference electrode.
