Wifi: "no module connected" / default sample rate / Daisy usage
Hi. I'd like to solve some problems that I had and ask some questions.
I
have tried to use the Wifi Shield with my Cyton board. I have set up
everything related to the network connection and when I use the
OpenBCI_GUI interface it's possible to find the Wifi Shield, but there
is message written that there is no module connected. Everything is
turned on accordind to the tutorial on the website, all the leds are ok
as well. What is the problem? Has someone had the same problem?
Other questions:
- The sample rate is 1000HZ using the Wifi Shield?
- Is it possible to use the Daisy Module? If yes, what is the sample rate?
I
Other questions:
thank you for your answers.
I have installed the newest version of the firmware and it worked! I still need to test the daisy module to verify the sample rate. As soon as possible I'll tell if it worked
https://github.com/OpenBCI/OpenBCI_GUI/issues/new
Please upload your saved data on the issue.
