cyton Radios programming question
acroarkacroark korea
edited July 2017 in Cyton
http://docs.openbci.com/Hardware/06-Cyton_Radios_Programming_Tutorial
Program DEVICE Radio with OpenBCI Dongle
i follow this part  and have some questions.
i bought the cyton board and i follow firmware version 2.x.x  . right ?
On the Cyton Board the pins you need to connect to are accessed from the BOTTOM of the board. Connect the jumper wires to the center of the pads as shown and press tightly while uploading to the Device. Helpful tips: Use a 4pin female header to keep the wires in place Don’t move your hand at all Place the board on a table or hard surface Keep the pins straight up and centered on the pads. (perpendicular to the surface of the pads)
holding the pins and uploading Radiopassthru32bit . next  uploading RadioDevice32bit . right ?
but result error, no target found .
so If the upload fails with No Target Found:
  1. Unplug the Dongle and Device.
  2. Plug the Dongle into your computer.
  3. Plug the Device into your computer.
  4. Put the device into bootloader mode.
  5. Try upload again.
i try that . but no difference ....
i make some mistake ? .
If you know anything about it, please let me know. please
thank you
