elizabeth
elizabeth
- elizabeth
- los angeles
- 63
- los angeles
- Website
- www.the-tarot.com, www.lisaconsulting.com
- @LisaSmirnoff
- Interests
- meditation, journalism, tarot, fashion, cooking, any kind of sport activities.
- marpasoft
It actually has 55,000 entries. but matlab is not saving a proper data.
[previous thread title: Reading the data question - what is he first raw that called sample] It goes from 1,3, until 255 and start over. Do these numbers mean anything?
Thank you, William!
"FFT of EEG does not really tell you very much, although it can show which frequencies are predominant." We need to have a window with the time, so when we use PlayBack widget, we can select a time for FFT event to see what happened during that ti…
thank you
Thank you! in which program you are doing it?
How do you mark events now during recording?
Yes, I did and I found this info online. I was not sure if I understand requirements.
my goal is to figure our hot to make changes to the scale from 20 to 30,000. I still have this question for me open.
Thank you! I know. Maybe they want to measure the noise of aircrafts. I promise you I am doing all background reading and will do more. scale did not make sense to me. and I need to speak up and start asking questions why. So far I am focusing on wh…
I hope I will figure it out.
It is my job to do all the readings and explain all things regarding the software. It was my idea to purchase it because I thought it was the best on the market for the purpose.
@wjcroft said: PLEASE have your company and yourself do some reading on EEG and emotion. See previous links. You cannot do this with FFT alone. So your entire outline of what you want to do at this point, would be extremely frustrating for all in…
See, my boss is a scientist. I just got a job, and need to follow directions. So I can learn programming, or anything he needs from what I understand, and I am grateful for opportunity to learn. To me, those just requirements and maybe later I will …
There will be a qualified people involved for setting and analyzing experiments. and for my sake, I read everything possible because it makes me easier to prepare everything for the experiments. to me, range of 20-30,000 did not make sense and I kep…
He was asking questions can we export time data (say 8 hours) in Excel. To me, it seems possible because the software does not put any limitations. and other question was can we picl event in 8 hour recording and get FFT of event. To me, why now if…
It maybe me. I need to have a different scale range and I am not sure and maybe I am asking wrong questions.
We trying to collect emotions based on specific events and see how they display.
Thank you for helping me.
2-8 hour recording for one session.
I listed all requirements above. I will not pay for a MATLAB because in case I will be given to me. MATLAB seems to be a main stream program and best to analyses data. WHAT REQUIREMENTS ARE: 1. I need to show PPT Plot of selected time frame ev…
To me, now it is clear what can be done with other programs and I did experiment with OpenVibe and I will download a free trial of MATLAB before asking for the license.
I need to do all kind of research before asking question why. I just need to learn if it is even possible and what will be the highest and the lowest range possible.
My boss tells me those requirements per each completed phase. Generally it is a neuroscience project and I just need to prepare the program for the next phase of requirements. the 30,000 is the last uV that my requirements are. Maybe the project req…
Thank you for the comments and links, William. I am now trying to understand how to make the scale from 20 to 30,000 work. Its my requirements I was given at work, and I am not quite sure what it measures. My understanding that uV are my (or whome…
1. iS the FFT based in the time periods 20,10, 5,3,1 seconds. Its the FTT of the 200 (10,5,3,1) second time period. Can we expand time of recording to 20 minutes, one hour, two hours. 8 hours. What if we have an experiment where we record brai…
Thank you.
Ok. I will try.
William, Thank you!
I just wonder if it is possible to create an executable file. I care for business people to use it because I had to download java environment and follow instructions to run processing. It could be much better just having an executable file. Thank yo…
