vinnyMS1
vinnyMS1
- vinnyMS1
- Canada
- 146
- Canada
Hi William, Thank you for your response and for the insights regarding AR glasses and the TGAM module. I understand the points you raised, particularly about the current high cost of smart glasses and the existing support for TGAM in other platfo…
I have the EEG recorded file as a csv file and I want to train a model of tensor flow to train it on the EEG csv file then I write a python script to train the model the EEG sensor only has one sensor; I also have the before and after type of traini…
can software determine the decimal value. if the eeg value is 1000.88 nomally can software make it 1000.888888
what are your thoughts about this app
https://www.youtube.com/shorts/pj7j6PNDQbY here it is, it's ready i was staring at the cellphone while it was speaking just so you know, it defeats the purpose because you have to be busy with a task while it speaks not just stare
i have created it already i will share the results later. the brain changes how it speaks every time it hears a speech through the gamma wave. when the person hears the gamma wave he or she can accept or reject. by rejecting the brain changes what i…
in the noise there's still valuable data just like a audio editor can split with accuracy what noise is in a sound file and extract the singers voice, the EEG that is noise can be filtered with software. the key is advanced software not advanced sen…
i created something different just with basic EEG electrodes it can make the brain speak directly with a software and a brain sensor. the gamma wave speaks in real time with 1 word per 1 second or 2 seconds i will use NeuroSky mindwave
@wjcroft said: Just found this paper, using cortical EEG (ECoG) to decode speech. https://www.frontiersin.org/articles/10.3389/fnins.2019.01267/full "Generating Natural, Intelligible Speech From Brain Activity in Motor, Premotor, and In…
@Billh said: Vinny, Imagine a basement of a large ten-story office building filled with a thousand typists, all typing different reports at once. You put a decibel sound meter on the outside of the roof of the building. You want to use t…
i created it already as a concept, it will work
it's possible the for the app to decode the EEG. but i want to know who would be interested in it. the gamma wave will speak in real time with a neural voice then while it speaks, the user will be able to control what it says with their brain by …
what happens if the android app works as explained. Is it something openBCI can support? I want to join an openBCI team if possible as an idea person. In theory the idea works already i need some more time to create it. I have some JAVA prog…
thanks a lot
i have a raw EEG .csv file with numbers. i want to know what's the maximum minimum number value i plan to create a EEG translator like google translate
play a movie and record the EEG a movie is the simplest thing to record EEG about. it's material that can be understood because there's the movie theme and subject matter so you can record EEG and expect to read the movie watching experience in the…
