pushtheworld
pushtheworld
- pushtheworld
- 847
Great!
Hi @Hamzahummam why don't you give me a ping on Skype and we can setup some time to chat! Sorry we have been so busy! pushtheworld_aj
What version of firmware is the Cyton running?
I think the best options is to use the Python driver and open up four different terminals.
If you send a 'b' over serial, the Cyton firmware will automatically lower the sample rate down to 250SPS because that's the max speed. You need to send the 'b' over WiFi in order to get this high sample rate!
Hi! Have you tried using the 192.168.0.4 IP address to directly connect to the shield?
Hey @dohor Sounds like the issue is from a power drain that happens with the Ganglion. You want to 1. EXT_PWR on WiFi to OFF position (down) 2. Battery in WiFi Shield 3. Battery in Ganglion 4. Turn WiFi Shield on (you will see those craz…
@wjcroft i met some of the neuromore team at BCI meeting and sounded like they were picking development back up! I hope they add support soon!
Hey Scott! Are you looking to stream over Serial? Or via WiFi? Thanks! AJ
Here you go! https://github.com/OpenBCI/OpenBCI_Wifi_Shield
@userjnl you just need a BLED112!
@kirandivakar @Matt16 please try the alpha^
Hi everyone! As @wjcroft suggested, I gave the BLED112 a shot on windows! You can download the new alpha of the GUI v3.4.0-alpha.1 that comes with Hub v1.4.5 which has support for windows over hub. I was able to test on two windows mach…
@Matt16 and @kirandivakar which version of the Hub are you running? Does running an older hub and GUI version solve the problem? Thanks!
I'm working on a new hub version that uses the built in bluetooth hardware, is there anyone here that can use this? I need testers!
Hi @FGL you should be able to run the standalone application. This is really strange that you are not finding any devices! I wish this was not the case. The steps you took should be able to work fine. Did you hit start scan a couple ti…
Hi! I'm curious as to why this is happening. Are the three LED lights on the wifi shield? Make sure you are powering the wifi shield from the Cyton! Thanks! AJ
Hi this feature was added by a community member and we need to get better docs on it! I know hte markers are supposed to be a single ascii character, which is then sent to the board. I opened an issue on this to add docs! https://github.com/…
William, I will plan to add BLED112 windows/linux dongle support when i get back into town next week. Seems there a number of people who want it Thanks for driving feedback! AJ
We’re slowly getting it!
I just fixed this!!! You can redownload the latest GUI and the hub that is in there is fixed!
There is only GUI support right now for the BLED112. We want to verify that this is working as well as we are seeing for all and we don't want to confuse more people with another dongle option for windows!
Hi!! Sorry for the late reply, please update the firmware of the WiFi shield! If you run into problems, Skype me anytime pushtheworld_aj
I feel like the wifi shield should work to LSL. is that not the case? an issue should be opened for this at once if that is something i can fix.
I heard you can use UDP to stream into matlab instead of LSL in the meantime. Your high pass filter should be at least greater than 1Hz, not 0.5Hz sorry
At a minimum you should use a high pass filter of 0.5Hz or greater
Wow @faheemersh this is so cool! We should feature your project in the next newsletter!
@compmonks this is actually a normal trait of the EEG signal, the DC drift! It's pretty cool totally normal to see.
LSL support in the GUI is horrible... people on all operating systems seem to have problems.
@petewall there was a bug in that build that i was unaware would be a problem, please redownload the release and try again!
