lagidigu
lagidigu
- lagidigu
- 96
Thanks a lot! Haven't heard of them before!
That is awesome to hear! Thanks a lot William!
Thanks for the quick answer! That would seem quite trivial then! Does that mean that the difference between the same measurement done with 5kOhms and 10kOhms is negligeable, or is there simply no difference at all? My main worry is that th…
Thanks a lot!
Hey ali, did you manage to assemble the headset with these springs?
Sure, you can find it here: https://github.com/lagidigu/FFT_Coherence/blob/master/Coherence.pde I am not sure whether or not I have computed it well though. The values are between 0 and 1, of course, but I have noticed the following: When…
Thanks a lot for the link! What helped me in the end was the following paper: http://www.ni.com/white-paper/4278/en/ I managed to compute the coherence of 2 FFTs in Processing, so it's in real time. If anyone is interested in the code, ju…
Here you go: http://www.ebay.com/usr/az6723 This seller is basicaly the one that was listed on the ultracortex tutorial. Their site is down, but they keep selling on ebay, and that's where I got mine from. Hope that helps
I should phrase it differently: I've looked throught all the processing code, everything I could find seemed to be the FFT, so we have the Complex Discrete Fourier Transform. Is that sufficient for getting the coherence of two channels?
Oh this is great! Thanks a lot!
Thanks for the answer! I read through the papers in the google search, and they don't differ that much from the scholar searches I made. The problem is that they are mostly fMRI studies, and it's hard to derivate whether or not you could identify …
Thanks a lot! Helped a lot!
To what degree would the signal quality be worse on the ganglion than on the cyton then? I don't want to make the mistake of purchasing a board that has an insufficient quality for the project that I want to work on... I'm really bad with the tec…
Thanks for the quick answer! How does using no cap at all, and only velcro bands/duct tape(?) with gel compare to using one? Will the signal quality suffer? I know that's a strange question, but to what degree do we lose signal quality when on…
