gilesforrest
gilesforrest
- gilesforrest
- 10
Thanks again!!
Hi, Are you running as administrator? --> Yes Do you have the OpenBCI GUI in a folder in Program Files? --> No! Should look like "Program Files/OpenBCI_GUI/OpenBCI_GUI.exe" --> Ahah! Is there a process running called Ganglio…
Hi...any thoughts on how to help?
For those using the video above, you don't need to install Python or Visual Studio first, simply install Node.js, extract Noble and run: npm install -g windows-build-tools This will install the correct versions of Python and VC++ for you.
I've raised an issue via Github
So I've gone through the whole Visual Studio, Python, Node, Noble install and the node program finds my Ganglion without issue: peripheral with ID ea0b6ab6750c found Local Name = Ganglion-40ed Service Data = Service UUIDs …
@celticharp sounds like similar steps to mine! CSR harmony driver installation, reboot, zadig override, reboot, try various USB ports and it started working Giles
Actually managed to get it to work - by trying another USB slot - perhaps the v2.0 are different to the v3.0?
I'm having trouble getting this working... I've followed the instructions to the letter on a Windows 10 Desktop and Windows 10 Laptop - with no luck. In all cases the Ganglion doesn't appear in the list of devices in OpenBCI GUI. After rep…
