Default Avatar
SpaceDonut
SpaceDonut
Username
SpaceDonut
Location
Austria
Joined
Visits
50
Last Active
Roles
Member
Location
Austria
  • I tried 3 locations, in two of them i already used the device in the past and it was working fine. So i really don't think this is the issue
  • Hi, Just a small update if someone gets some ideas. The support team also thought about ear clips. I replaced them with new ones, but it didn't help. I also noticed that about 70% of packets are lost after i became an warning message in GUI. Could…
  • Today I tried moistening my earlobes and pressing on the ear clips. This two actions returned the Railed to its normal values, on channel 10 I can even see myself blinking hard, but the noise is still quite loud so it's impossible to see anything el…
  • I will try it all, thank you, and let you know if it helps!
  • I already wrote to the service over the weekend, but they still haven’t answered me, so I wrote here. I've been using the headset for two months about once a week. It is very strange that one evening I had good EEG readings, and that same evening …
  • Swapping didn't help. Regarding ambient interference - in general the device already worked fine in this place, so I don’t think that’s the problem, i turned off the lighting, no changes. Another room also doesnt change much. One time when i swapped…
  • I checked the connection on both ear clips with a multimeter. On the SRB clip the value is close to zero when checking the contact, and on the BIAS ear clip it is slightly higher. You can see the photo in the archive on my Google drive. I also attac…
