Samvb
Samvb
- Samvb
- Sydney
- 286
- Sydney
Hello again, Are you able to provide any advice regarding my previous posts? Is what I have suggested correct? or is there a different process I would need to follow? Thanks for your help, it is much appreciated. Cheers, Sam
Hello again, Just following my previous post. Is what I have suggested correct? or is there a different process I would need to follow? Thanks for your help, it is much appreciated. Cheers, Sam
Hello, Just following my previous post. Is what I have suggested correct? or is there a different process I would need to follow? Thanks for your help, it is much appreciated. Cheers, Sam
Hi wjcroft and retiutut, Thanks for your advice. I see the 'Max file duration' options are included in SessionSettings.pde. See line 53 for 'defaultOBCIMaxFileSize'. https://github.com/OpenBCI/OpenBCI_GUI/blob/master/OpenBCI_GUI/SessionSettings.pd…
Hello! Just following up my previous post. Is it possible to change the GUI default settings? Thanks for your help! Cheers, Sam
Hi William, Thanks for your advice. I may just use an older GUI (v5.0.9) that does not have the pop-up feature. Am I correct that saving to a micro-SD card mitigates any bluetooth issues? i.e. If I experience any bluetooth connection issues (from…
Hi William, I am expecting my bluetooth stream to cut out as the user may be moving away from the dongle at times. Therefore, I am planning to also save the data to a micro-SD card on board the Cyton. I am wondering if there is a way to stop the 'S…
Hi William, Thanks for your help. I have emailed [email protected] and I have also purchased the extension cable. Cheers, Sam
Hi wjcroft, I am also looking for a script to convert SD card files (hex) to decimal. Is there a new link to the above code? Thanks, Sam
I am trying to open the cyton board schematic and PCB files using Fusion360. I have downloaded the zip files from the V3_Hardware_Design_Files thread on the OpenBCI Github. However I am unable to open them using Fusion360. Do I have to use Design…
Hi retiutut, I am using a USB extension cable and it seems to have fixed my problem. If it occurs again I will take a video recording and will share it here. Thanks, Sam
Hi William, Thanks for the advice. I will try a USB extension cable and will also look into the box idea
Hi William, I am running a series of tests investigating EEG data from the Cyton board and transcranial doppler ultrasound measures (taken from the temple of participants at a number of time points throughout each test). Unfortunately I do not have…
Hi William, Thanks for your fast reponse. I am using several sparkfun breakout boards as the additional sensors (MAX30105 for oximetry and temp, sparkfun Sound Detector - SEN-12642 (this is what I meant by sound) and sparkfun ambinet light senso…
Hi William, Thanks for your help earlier this year. I am now revisising my post. I understand the Cyton board has three 'aux' channels that I could use for additional sensors however if use these channels for another sensor, it removes the a…
Hi William, I did try a few other USB ports with no luck. But for some reason it has started working again. If it stops again I will install the latest FTDI VCP driver Thanks, Sam
Thanks Billh
Hi William Thanks for your reply, Do you think I would be able to add particle sensor ( https://www.sparkfun.com/products/14045?_ga=2.16289270.1947926216.1568703092-628748718.1555989600 ) to one of these extra channels? Does the ganglion board al…
Hi Wiliam That looks like a very interesting project. I am not interested in neurofeedback but I could probably still use their sensor. How can I get in touch with Josh? Kind regards Sam
Thanks Billh Do you have any advice as to what arduino product would be best for this application?
