Ok. Final update. I installed older version. 3.0.1 stand-alone application on 64bit Windows 10 system on Lenovo Ideapad360. Used CSR dongle ordered from open BCI. Installed it with the CD that came with it. Used Zadig. Restarted the system with dongle in place. It installed windows update. It is working well now.
Here are my observations.
1) when you plug in CSR dongle, even without the installation with software, it does show as blue tooth device, but it seems that system has no access to it. So when you install the software, windows starts showing it as an independent blue tooth devise and you can inspect its com port and hardware configuration etc. You can also check if it 'sees' the ganglion. It sees, but it cannot connect, because there is no way to return the code from ganglion devise, as happens with other blue tooth devices.
2) Now when you change the driver with Zadig, you no more see the system recognizing it as blue tooth device and you cannot access its details. But i think that first software installation is necessary for comport. Because when i tried without it , the GUI could see the ganglion but could not connect and gave comport error.
3) After that you have to reboot the system which then runs windows update. I think at this time, the system recognizes the driver and adjusts the com port.
Thereafter it has been working fine, so far. I think the key change was using earlier version of HUB (3.0.1 which shows the cat icon in the system tray.)
As @wjcroft suggested, I gave the BLED112 a shot on windows!
You can download the new alpha of the GUI v3.4.0-alpha.1 that comes with Hub v1.4.5 which has support for windows over hub. I was able to test on two windows machines running windows 10. Please let me know if you have any troubles!
Thanks for posting the alpha; I was just about to comment that I still could not get the Ganglion to interface with my Windows 10 computer and it worked! However, when I selected CSR BLE it found it... This makes me very puzzled as the prior versions would refuse to find the board via CSR saying that the drivers were not installed and giving me the same 412 error. What happened in this new version? Again, not connecting via BLED, but rather an official CSR dongle.
Let me give the solution that worked for me and my friends ganglion devices. We simply installed electron hub version 1.3.2 and latest BCI GUI and it worked like a charm. (Don't forget to say thanks)
any troubles!
