Ganglion high pass filter problem
Hi!
According to some notions ( please see that for reference: alexandre.barachant.org/blog/2017/03/02/Hands-on-OpenBCI-Ganglion.html ) there is a design flaw, that leads to 2.4Hz high pass filter and strong signal attenuation below 10 Hz. Actually it is not acceptable for correct EEG processing, since it has physiologically important spectrum from 1Hz and up.
So, what are perspectives to resolve this issue in the nearest future?
Best,
Alexei
Best,
Alexei
So, all current Ganglion stock in openbci store has only units with updated schematics, right?
Also, Please correct according section of schematics description. It still contains old RC filter parameters.
Thanks again,
Alexei
Michael
Best regards,
Michael
several Ganglion boards, as well as other products from openBCI, so I'm
obviously an investor in the project with a stake in its success. The
projects's handling of this development is truly discouraging..
Customers should be made aware that this is a serious problem with the Ganglion board. The
incorrect filter parameters mean that Ganglion output is not comparable
to commercial or research EEG hardware, or to published research
findings that use conventional EEG hardware. It does
not meet the "research-quality biosensing" claim on the openBCI home
page. The problems described fall squarely in a frequency band that is
often of interest to users.
My operational Ganglion board has
been gathering dust since I read about the issue early in October.
After receiving no response to my question, I stopped using it and
ceased making any recommendations or references to the Ganglion for the
last two and half months.
The least that openBCI should do is to
publish a full disclosure of the issue with an updated schematic and a
tutorial on how to make corrective modifications. In other DIY
communities, the vendor would have immediately shipped the necessary
parts to owners free of charge. I have seen this done often in both the
amateur radio and electronic music DIY communities. Since the Ganglion
comes assembled, something also needs to be done for users not capable
of performing surface mount modifications themselves.
The answer lies in thinking about user needs and applying common sense about good customer service.
Best regards,
Michael
