How to know what channel names to enter for Ganglion in OpenViBE
hackrhackr Maryland, USA
edited September 2017 in Ganglion
I've been working with the motor imagery set of example scenarios in OpenViBE. I'm able to record the training brainwave data from Ganglion.
However, when I get to the 3rd .xml file (scenario) the scenario fails because it requires you to enter the name of the reference channel in the "Reference Channel" box. The name of the channel in their example was "Nz". How can I determine what name I should give for the Ganglion's reference channel?
I believe I'm about to have the same question for the rest of the channel names, because once this box is working the next one is the Channel box, which has 4 different channel names in it.
Thanks in advance!
Update: I think I found something that shows a way you could figure it out with the Windows version, but I'm not seeing anything like those diaglouges in the Linux version...
  • hackrhackr Maryland, USA
    I think I figured it out. I just used the names from the Signal display, i.e. Channel 1, Channel 2, Channel 3, Channel 4.
    I guess that was obvious. I was just expecting them to have names more like the ones in the example scenario.
