Ganglion board now working with python on Linux
2»
  • Never thought to look at that! "signal display" box has some glitches, maybe this is why. I don't think over boxes are affected. Did you try to reduce the chunk size (here "sample count per buffer") in the acquisition server? Try 4 instead of 8, a multiplier of the sampling rate is always a good idea. If you do time-based epoching you can actually count the number of values in a epoch of xx seconds.
    If you need to discuss further, you might want to open another thread (or even better, "port" the discussion to OpenViBE forum, this issue is likely related to the LSL driver in general).
