AJ's new Wifi Shield / beta testers signup
The note below is from AJ Keller @pushtheworld, regarding the beta testing of the new shield. Great work AJ & Joel.
There are ten beta boards shipping out next Friday and people can sign up for beta here: https://docs.google.com/ forms/d/e/1FAIpQLSfjMzITl3Z_ bMxCZlXaUVHxj0vVZ6oXyk3G05epOM YWBOiAFA/viewform
A little about the board:
- The board was made in partnership with Push The World and OpenBCI. The hardware and firmware were designed and implemented by Push The World and OpenBCI funded and advised the project.
- The board will eventually work on the ganglion
- Uses new 3.0.0 OpenBCI Cyton Firmware which allows for programmatic sample rate changing along with a couple other simplifications to the library.
- The 3.0.0 OpenBCI Cyton code will still be 100% backwards compatible with v1.x.x and v2.x.x, i.e. by default the board will want to use the dongle and a user would never notice that the board could use a wifi shield. I did this to allow the wifi capable code to be flashed to boards when they leave the factory.
- Push The World will provide and maintain a NodeJS connector/driver.
- In a later hardware release, we will add an ADS1299 to the board and people can choose to buy the shield with a populated ADS1299. Allowing for a 24 channel configuration.
