Ganglion, V2 GUI freezes on "START SYSTEM"
Setup:
-MacOS 12.12.2 Sierra-OpenBCI_GUI_200_MACOSX (downloaded 1/31 from http://openbci.com/index.php/downloads)
-Ganglion Board blue light blinking
-USB dongle blue light blinking
-Bluetooth is on
-no other Bluetooth devices are connected.
Steps:
-open OpenBCI GUI
-click data source LIVE (from Ganglion)
-select my ganglion board.
-hit "START SYSTEM"
-waited 10 minutes, still nothing (documentation said it might take up to one minute)
Synthetic signals work fine.
Can you report any log type messages you see in the Processing windows?
Mentioning @Conor and AJ @pushtheworld. Any other troubleshooting steps you can recommend?
For example (not Ganglion but...) with Cyton we were able to connect to the serial port with a terminal emulator and verify the link was up and debug info printing. Is there some similar debug stream we can see with Ganglion?
Could his macOS Sierra be an issue? But he is starting it ok, so must be past the app signature stuff.
http://openbci.com/forum/index.php?p=/discussion/951/v2-gui-with-cyton-frozen-at-start#latest
Mentioning @Conor and @pushtheworld
https://github.com/OpenBCI/OpenBCI_GUI/issues/118
Now it does not freeze, but I am having a new issue.
Matt, I think a warning about this will be added to the tutorial,
https://github.com/OpenBCI/Docs/issues/67
@matt16 we developed this hub on macs so generally the software works really well with them, or so I've seen, because they are so consistent in hardware. Windows, on the other hand has no restrictions on what hardware run on it, so it's best to go to a constant dongle to ensure the great brainwave data! Good luck and please be sure to talk about your adventures with the community!
Thanks @wjcroft for the issue report!
