Ganglion on Mac running Windows VM, no bluetooth?
Hi everyone,
I just got my ganglion and it is working fine on my MacOS Sierra. I just had time to test the OpenBCI GUI. I would like to eventually connect my Ganglion on Windows apps running on VMware so I installed the OBCI Gui on my VM windows10 but could not get it to connect. I think the issue has to do with the way it connects thru bluetooth. It is not a "normal" bluetooth device that can be shared to the VM. Even MacOS needs the GanglionHub to connect to it. I tried running that app but it did not help.
I am thinking I will probably have to install Windows on bootcamp to bypass this connection problem, but maybe there is an easier solution. Maybe getting a usb bluetooth dongle that I will connect directly to my VM would work (when I plug a usb device with my VM running, I get a choice to connect that usb device to mac or windows).
I have seen this page on the site about installing FTDI drivers on a VM but I guess this is for the other openBCI devices that connect differently than the Ganglion. Maybe this would help if I had a bluetooth dongle !?
- If using Virtual Box: Enable FTDI FT231X USB UART on virtual box throughDevices > USB Devices.
Any help and/or suggestion is greatly appreciated.
The FTDI info is for Cyton, not Ganglion.
Try the CSR 4.0 dongle accessed inside your Windows VM,
http://docs.openbci.com/Tutorials/02-Ganglion_Getting Started_Guide#ganglion-getting-started-guide-downloadrun-the-openbci-gui-on-windows
