As mentioned on another thread, I got an update from the good folks at chipKIT that they have a link compatible with the Arduino Boards Manager thing, and I will be testing with the 1.6.5-r5 and later versions of the Arduino IDE this week.
Since I decided to build my OpenBCI hardware from the scratch I learned in hard way that if You don't have information mention above You will waste some time trying to debug hardware.
I've built the boards from the documents, though I've hit a problem.
I upload the boot loader to the board with a Pickit3 which all goes fine(Blue led flashing, update succesful) Though when i then try to enter boot loader mode nothing happens, i.e. no flashing LED. The LED obviously works, because it flashes when transferring the boot loader, and the boot loaders definitely on there, so I'm very unsure where to go next.
Some time ago You mentioned about:
In this paragraph:
Cheers,
henryk
