Large 50Hz noises when recording ECG
I used channel IN1P, IN1N, and BIAS to measure ECG using V3 hardware. I had set SRB1 and SRB2 to OFF, and included only channel 1 for bias generation. But there were large amplitude of 50Hz noises and its harmonics (like 150Hz, 250Hz, etc), which was so large that it was impossible to observe the ECG signal. I did use the RLD to reject the common mode using the bias pin, but it seemed not working. Any suggestions? Thanks in advance.
Is the noise also present with EEG tests? I assume you've followed all the steps in the doc,
http://docs.openbci.com
