sample rate drift increased over last few days -> FTDI Latency
Hi everybody,
I noticed something strange on my setup.
I'm using Openvibe for a few weeks, great software by the way.
When I started the connection in the acquisition server the device drift was around 0.50ms, since a few days it's between 2ms and 6ms.
The refreshing rate is then much slower in the designer part of Openvibe. I'm still able to get data from the electrodes but the acquisition rate is slow.
I also notice in Openvibe after pushing "play", just below the device drift feedback, it was written "sending... 1 host connected", now I have "sending... 0 host connected".
This is very strange, I didn't do anything special. I first reflashed my openbci32bit but it was still slow. I also installed Openvibe on a different computer, removed and reinstalled the driver of the dongle on my PC, nothing changed back.
I also checked the connection with the Processing IDE but I had the same problem. The battery is fully charge.
I'm using the last code for both host and device RFduino and I'm flashing the 32 bit micro with the last arduino IDE trick.
After a few days checking everything I'm a bit lost, I probably did something but I can't find what... Maybe one of you could give me some clues?
Thanks a lot for your support!
Arale
http://openbci.com/forum/index.php?p=/discussion/200/latency-timer-windows-control-panel-setting
Perhaps it's possible that Windows might reset this to defaults under odd conditions.
Are you saying the GUI does not work at all? Or that you see pauses, bursty-ness? Or that the entire sample rate seems to be consistently less than 250 sps (4 ms per sample).
I'm also going to mention Jeremy @jfrey here, who wrote the OpenViBE driver and has the most experience.
http://www.ftdichip.com/Drivers/VCP.htm
Can you check your Device Manager control panel and see what version you are running. Also what Windows OS. You might try a Linux test as well.
