Run OpenBCI on LiPo battery
I was wondering if it would be possible to use OpenBCI board with a LiPo battery like https://www.sparkfun.com/products/341
I assume that the OpenBCI 8bit version runs on 5V, thus I can simply use a booster to boost 3.7V battery to 5V. Should there be any issues with that?
Mike
http://openbci.com/forum/index.php?p=/discussion/135/lithium-battery-recommendations/p1
I chose this because the 500C has a built in charger, low battery indicator, etc. I'm going to keep the PowerBoost board and LiPo at a distance from the OpenBCI board. For example in pants pocket or on belt loop. With the 5.2 DC cable running to the OpenBCI board, clipped to my shirt near the collar or shoulder. (I use short sensor cables, 40" long.) That slight .2 V addition ensures any 5 V regulators are fully functional.
The separation serves two functions: to keep the OpenBCI light as it is clipped to cloth. And just in case there is some mild RFI / EMI radiated from the booster, the distance will eliminate that factor. Plan to do some scope tests to see if I notice any noise coupling into sensor cables by varying the distance, close and far.
Of course for safety you only want to do charging with the PowerBoost while you are not wearing any sensors.
I have been using the Adafruit Powerboost 500C with one of their lithium batteries and OpenBCI. Seems to work just fine. I used the live spectrogram in Brainbay to see if I could detect any interference from the 500C getting picked up by the sensor wires / amplifier. None that I could see. Tried positions both near and far from the OpenBCI board. No differences seen.
The 500C does have a small inductor coil, from their docs I believe this is running around 700kHz. Even with that inductor positioned right over the ADS1299 or other parts of the board, no noise was seen on the display.
The 500C has had it's share of comments on the Adafruit boards. I think mostly people using it in unusual circumstances. So please take my usage as an example only. OpenBCI project is not promoting any particular booster or charger as the "recommended" lithium power solution.
I measured the current drawn by the OpenBCI board. It appears to be the same regardless of whether the board is transmitting or not. 50 milliamps. The 2500 mAH lithium cell I got from Adafruit on the same order is thus somewhat overkill. (2500/50 = ~ 50 hours). They also have 500 and 1200 mAH cells, which would work out to be 10 or 24 hours respectively. The Adafruit site mentions the TI booster they use runs at about 90% efficiency.
As one more data point, using the 4 AA cell holder with NiMH rechargables, does not work that well. The nominal rating of these cells when charged is 1.2V, though mine were coming up to 1.3V. 1.3 * 4 = 5.2V. Enough to satisfy the 5V regulator, but not for long. If your NiMH's only hit 1.2V, that is 4.8V(!) The 4 AA NiMH cells would work better with the 32 bit OpenBCI, since that uses a 3.3V regulator.
i am totally confused on how to connect the pins of ADS1299 namely BIAS_IN, BIAS_INV, BIAS_OUT and BIAS_REF. what does the BIAS_ELEC do? I am desperately in need of help..
http://openbci.com/forum/index.php?p=/discussion/170/getting-started-confused-about-srb-and-n1p-pins/p1
Just use the BIAS pin on the same side as the other pins you are using. Both BIAS pins are the same signal. The BIAS_* lines are connected appropriately INTERNALLY on the board, you don't need to worry about that. The external pin on the header is what you want.
Remember, there is SEARCH box on the forum. For example, search on 'bias' will find multiple entries.
thanks a lot...actually m working on a pcb and not on the kit and this time m stuck with the srb pins. actually m using a common ref electrode, so if it is connected to srb1 then shud i leave the srb2 pin floating and what bout the negative pins?? shud they be shorted externally to ground or avdd??
thanks,
akriti
You might also try searching on the TI forum,
http://e2e.ti.com/support/data_converters/precision_data_converters/f/73/t/374626.aspx
This conversation would be better placed in another topic. As it is not related to the LiPo subject line.
Thanks, William
You can use a couple of these JST-PH extension cords, removing the connector from one end and soldering the wires onto the 5V and GND holes of the PowerBoost 500C. Far end of the extensions just plugs into the OpenBCI. Each cable length is a half meter long. I placed the booster + battery in my pants pocket.
http://www.adafruit.com/products/1131
Photo of booster on top of battery, using removable double stick foam is on the bottom of this page.
https://sites.google.com/site/biofeedbackpages/velcro-sensors
You could actually place a smaller battery + booster closer to the OpenBCI. I put mine in the pocket to keep the OpenBCI board light enough to clip onto my shirt. I unplug the battery from the booster when not using it.
http://www.adafruit.com/products/1944
I found no interference whatsoever in my tests. I've not used multi cell Lithium packs, but for best and safest charging, don't you need to have a charger that levels each cell independently? Sounds more complex than this simple combo board and one cell. With a booster you also get the full amp hours and battery life possible from the cell. And the low battery cut-out avoids possible damage to the cell if the voltage drops too low, since Lithiums are sensitive to this.
You do need a balance charger for multi-cell lipos, but they're quite inexpensive and simple to use -- you can get a serviceable one for about five dollars on hobbyking.com. I can send links to the HK chargers I have when I'm in the same place as they are...
The Powerboost puts out a constant 5.2v regardless of the lithium cell voltage or charge level.
http://openbci.com/forum/index.php?p=/discussion/157/battery-on-the-32-bit-board
https://cdn4.pcadvisor.co.uk/cmsdata/reviews/3532885/Olixar_enCharge_Power_Bank.jpg
Interesting about the whine you're hearing. The Powerboost 500C I have here is completely silent. Does the sound dampen somewhat when you press down on the coil on the board? There is a discussion forum at Adafruit for this product. You also could probably get an exchange. Another thing to try would be to use some potting compound (like silicone or epoxy) around the coil. But that would preclude your exchanging it. Any switching type supply uses a hi freq oscillator like this. The 500C supposedly is running at 700KHz; so that must get translated down into audio range like with a subharmonic.
