Problem regarding the EEG signals captured
recently, I brought an OpenBCI headband kit with 8 electrodes. when I record the EEG signals and plot it it with mne the signal showed an uptrend as in the image EEG_raw_signal. the signal was saved in the format of .bdf. same problem goes when I save the file with OpenBCI txt form.
I tried to plot the Power Spectral density plot too and in the plot it shows that the power is gone below 0 as shown in the image EEG_raw PSD.
This is the hardware set up of the device (hardware setup).
please give me a solution to this problem.
    Paul, hi.
    The recording / raw data files from the GUI, are RAW. NO filters have been applied. You need to use a DSP library (digital signal processing) that has filters to apply, at the minimum: say a bandpass from .5 Hz to 40 Hz. And a notch filter at your mains frequency, 50 Hz. The first image shows both tremendous mains noise, and the DC offset potential slowly increasing. The offset represents frequencies below .5 Hz.
  • I used the filters as you asked to my raw EEG signal and below is the plot I got (filtered signal). when I plot the power spectrum still the power goes below 0 (psd filtered signal).
    edited February 2024
    Read the link I posted. Cannot see your FFT / PSD graph. If you apply the filters correctly everything should look identical to what you saw on the GUI with your filter settings there.
    Suggest trying a different FFT graphing routine.
