error connecting to Cyton Board [resolved, old firmware]
rmib200rmib200 Bolivia
edited June 27 in Cyton
Hi! I recently tried to connect a Cyton board (the same as the attached image) but I got an error when I try to connect it to the GUI. I'm using GUI v.5.0.3 and the board is Cyton V3-32. The dongle is recognized but the trouble appears when trying to connect to the board. I've tried different usb ports for the dongle but no success. This board was kindly donated by Taran from Linus Media, and we are trying to set it running for our projects. Please any help would be appreciated.
This is the Log I get.
Console Log Started at Local Time: 2021-03-23_15-05-33
Screen Resolution: 1366 X 768
Operating System: Windows
OpenBCI_GUI::Setup: GUI v5 Sample Data exists in Documents folder.
ControlP5 2.3.1 infos, comments, questions at http://www.sojamo.de/libraries/controlP5
Local Version: v5.0.3, Latest Version: v5.0.3
GUI is up to date!
CP: Playback History Size = 2
sourceList: click!
Channel count set to 8
ControlPanel: Found Cyton Dongle on COM port: COM9
CytonAutoConnect: Error reading from Serial/COM port
[WARN]: Found a Cyton dongle, but could not connect to the board. Auto-Scanning now...
[ERROR]: Unable to connect to Cyton. Please check hardware and power source.
    @wjcroft Does this need a firmware update?
    Richard and Rmib, hi.
    Yes, I believe Taran purchased this multiple years ago, and the firmware likely needs updating both the two RFduinos (dongle and mainboard), and the main cpu, PIC32 / chipKIT.
    https://github.com/OpenBCI/OpenBCI_Cyton_Library/blob/master/UPGRADE_GUIDE.md
    https://docs.openbci.com/docs/02Cyton/CytonRadios
    Just to verify the boards work, could he first try a very old GUI version? Which one?
    I think it would be easier to use the Cyton SDK and Arduino Serial monitor to check board version. Another way is to run GUI v4.2.0 and it might print the Cyton firmware version to the console log.
    Richard, thanks. Other programs which are known to work with the original Cyton serial port protocol are BrainBay and OpenViBE.
  • rmib200rmib200 Bolivia
    This is the Log that I get when using GUI v.4.2.0.
    I guess the Cyton firmware is v1.0.0
    Console Log Started at Local Time: 2021-03-24_14-39-30
    OpenBCI_GUI: hubStart: OS Detected: Windows
    Local Version: 420, Latest Version: 503
    GUI needs to be updated. Download at https://github.com/OpenBCI/OpenBCI_GUI/releases/latest
    OpenBCI_GUI::Setup: Sample Data exists in Documents folder.
    The file "C:\Users\Win10\Documents\OpenBCI_GUI\Settings\UserPlaybackHistory.json" is missing or inaccessible, make sure the URL is valid or that the file has been added to your sketch and is readable.
    Instantiating hub object...
    Hub: CheckHubInit: The GUI is connected to the Hub!
    sourceList: click!
    setInterface: curInterface: -1
    channel count set to 8
    Setting Latency to 10000
    Setting WiFi Internet Protocol to udpBurst
    Setting WiFi style to dynamic
    [DEFAULT]: Protocol Serial Selected for Cyton
    setInterface: curInterface: 0
    Setting sample rate for Cyton to 250Hz
    sample rate set to: 250
    [DEFAULT]: Transfer Protocol set to serial
    ControlPanel: Attempting to connect to COM9
    ||             INITIALIZING SYSTEM             ||
    Hub: processConnect: made it -- 17074 code: 200
    Hub: setBoardType(): sending 'cyton -- 17074
    Hub: processBoardType: success -- 17075
    [SUCCESS]: The GUI is done initializing. Settings Loaded! Press "Start Data Stream" to start streaming! --  Cyton firmware v1.0.0
    Cyton: startDataTransfer(): writing 's' to the serial port...
    Hub: sendCommand(char): sending 's'
    SoftwareSettings: 3 active widgets saved!
    Closing any open SD file. Writing 'j' to OpenBCI.
    Hub: sendCommand(char): sending 'j'
    Hub: processCommand: success -- 17969
    Disconnecting serial...
    [ERROR]: Check that the device is powered on and in range. Also, try AUTOSCAN. Otherwise, Cyton firmware is out of date.
    @wjcroft @rmib200 My Cyton with latest firmware shows v3.1.2 using GUI v4.2.0.
    Btw, I tried with an older version of the GUI v3.4.0 and also no luck :/
    @wjcroft Do I need to upgrade to v. 2. 0 first and then upgrade to v 3.0? or can it be upgraded directly to v.3?
    Follow the steps at "Upgrading to 2.0.0" in,
    Going from 2 to 3 is just a new PIC32 mainboard firmware. You need to upgrade the RFduino radios first in the "Upgrading to 2.0.0" steps, since you have firmware 1.
    @wjcroft Hey there! I've been trying to follow the guide but I'm stuck in one step.
    ---In the Arduino IDE 1.5.8 go File-->Examples-->OpenBCI_Radios-->RadioDevice32bit which will launch the Device firmware.
    I unzipped the folder with the OpenBCI_Radios and from the Arduino Examples list I cannot find the "RadioDevice32bit" option. I looked many times but I don't find an exact (or similar) option. Could I have done something wrong? Or maybe the option that I'm looking for is under a different name ?
    Hi!! I managed to get this far. I followed the tutorial for the usb dongle and now I'm trying to update the board. With Arduio 1.8.15. But I get this error.
    The board still is not recognized by the GUI. It seems that the problem arises when the code is being uploaded to the Cyton board.
    I'm using ChipKIT core 2.0.6.
    What can be done to solve this issue?? :/
    Did you complete all these steps in the order required? Which steps were successful, and which are not? To be upgraded are the two RFduinos (mainboard and dongle), and the PIC32.
    I would say that all the steps where succesful until this last one. Is there a way to make sure that the Pass Thru Radio Firmware was correctly uploaded to the Cyton Board?
    Can you answer my question? Which chips have been successfully reprogrammed?
    Your photo seems to imply that you are at the VERY FIRST step in the three chip reprogramming. This first step reprograms the mainboard RFduino (called the 'device'), using the dongle RFduino ('host') as a passthrough.
    https://docs.openbci.com/docs/02Cyton/CytonRadios#uploading-device-firmware-to-cyton-board
    edited June 28
    I would say that all the steps where successful until this last one. Is there a way to make sure that the Pass Thru Radio Firmware was correctly uploaded to the Cyton Board?
    Are you certain about this statement? Your photo seems to show NOT the last step, but the first. (Programming setup for flashing the mainboard RFduino.) The pass thru program is loaded onto the dongle, so that it can then be used to reprogram the mainboard RFduino, via the link below. This uses hand held contacts to the underside of the board.
    I'm not on the first step. I've completed the steps on the Cyton Radios. Just sending the pic to confirm that. I'm trying to upload the Cyton Firmware. Is there a way to check if the previous steps where done correctly? I don't know anything about hardware so I'm pretty much working blind here. A little help wouldn't be bad.
    edited September 9
    OK, your photo confused me, it looked like you were setting up the passthrough. Did you get all the correct messages from the Arduino IDE app, as you completed the firmware uploads to the mainboard ('device') RFduino, and dongle RFduino ('host') ?
    If your RFduinos are healthy, you should be able to use the features in the OpenBCI_GUI that change or adjust the radio channels.
    Expand section 5 by clicking the arrow. Try the commands: Get Channel, Change Channel, Autoscan.
  • I tried re-doing all the steps in the tutorials and I got an Error during the Cyton Board Programming. I've put the board on Bootloader mode, try to upload the code of the DefaultBoard script and got an error that says "No target found." At the moment I tried with Chipkit v 1.3.1 and the 2.1 (newest). Both return the same error.
    From the OpenBCI_GUI I've tried to check the status and got this message:
    "Error reading from serialport. Try a different port?"
    I've tried changing the port and using a different computer but the error stills the same.
    So far, the only script that is giving me trouble is the Cyton Programming "DefaultBoard" in the arduino 1.8 , in all of the others scripts from Radio Programming I got a message that said "Succesful!". :/
    Also, I have a couple of questions of the procedure where a clarification may be useful. Should the Cyton be turned on or off during the procedure where the jumpers needs to be touching the right position? Should the pins be touching the Cyton board for the Cyton Programming part? Is there a way to connect the Cyton board directly to the PC?
    Please help, I don't know what else to do.
    edited September 8
    Did you see my previous comment, about verifying that the RFduino's (dongle and mainboard) are correctly 'talking' to each other??
    Fixed "Optional Settings" link above.
  • Yep, I also post the error I got when I verify the RFduino on the GUI on my last post.
    Did you try the AUTOSCAN button?
    edited September 9
    yes
    I'm not sure that I am communicating my intention with you correctly. The purpose of verifying that the two RFduino's are communicating with each other, is that this communications channel is how the mainboard PIC32 is re-flashed. If the RFduino's are not able to change channels or AUTOSCAN, it means that the RFduino firmware reflash was not successful. Thus you need to repair the broken RFduino's first, before you can flash the PIC32.
    edited September 9
    This is my procedure in order: (During the Cyton radios programming tutorial)
    • Download Arduino 1.5.8 BETA -> Download and extract OpenBCI_RFduino -> Download and extract OpenBCI_Radios Firmware -> Connect the pins of the breadboard connected to the dongle (switch on RESET) to the bottom of the board. (Since the buttons on my board are blue I don't use the 0.1uF Capacitor, my board is connected to the 4 AA battery pack and turned ON).
    • Upload DEVICE Radio Firmware Version 2.x.x found on File-->Examples-->OpenBCI_Radios-->RadioDevice32bit -> add line radio.flashNonVolatileMemory(); on the setup() function -> Result "SUCCESS" -> Redo this step but with the radio.flashNonVolatileMemory(); on the setup() function COMMENTED -> Result "SUCCESS".
    • Upload Pass Thru Radio Firmware Version 2.x.x (Fall 2016) -> Follow same procedure of connecting the pins to the bottom of the board -> the run scrip found on File-->Examples-->OpenBCI_Radios-->RadioPassThru32bit -> add radio.flashNonVolatileMemory(); on the setup() function -> Result: "SUCCESS" -> Redo this step but with the radio.flashNonVolatileMemory(); on the setup() function COMMENTED -> Result "SUCCESS" .
    • Upload HOST Firmware Version 2.x.x (Fall 2016) -> Script used is found on File-->Examples-->OpenBCI_Radios-->RadioHost32bit. This time without connecting the pins to the bottom of the board and still having the dongle on RESET. -> Result "SUCCESS".
    • At this point I went to the OpenBCI GUI to check with the latest guide you post and press CYTON -> Serial (from Dongle) ->AUTO-CONNECT-> "Dongle is connected but couldn't connect to the board." -> Manual settings (My GUI doesn't have a button that says OPTIONAL SETTINGS) -> AUTOSCAN -> "Dongle is connected but couldn't connect to the board." -> SYSTEM STATUS -> "Error reading from serialport. Try a different port?"
    Then I did the Cyton Programming tutorial (This is my procedure in order):
    • Install arduino 1.8.16 -> Follow guide to download OpenBCI_32_bit_Library, OpenBCI_32bit_SD, OpenBCI_WiFi_Master. -> Follow guide to install ChipKit Core. (First tried with version 1.3.1 as recommended)
    • Select DefaultBoard.ino from Examples ->File-->Examples-->OpenBCI_32bit_Library-->DefaultBoard-> Dongle switch is set to GPIO6 -> Put Cyton on Bootloaded Mode -> Board it is blinking -> Upload the Firmware -> Result "No target found." Error.
      Then I've tried with the latest chipkit core but still got the same result. "No target found."
    • At this point I once again go back to the OpenBCI GUI and pressed CYTON -> Serial (from Dongle) ->AUTO-CONNECT-> "Dongle is connected but couldn't connect to the board." -> Manual settings (My GUI doesn't have a button that says OPTIONAL SETTINGS) -> AUTOSCAN -> "Dongle is connected but couldn't connect to the board." -> SYSTEM STATUS -> "Error reading from serialport. Try a different port?"
    I've tried with two different PCs. What am I doing wrong?
    The pass through program must be put on the dongle, BEFORE flashing the mainboard RFduino ('device').
