Cyton with BCI2000 P3 Speller / slow buffering
lisapelagalli
Italy
Hi everyone,
I'm working for my thesis with OpenBCI Cyton board and I want to use BCI2000 for a P3Speller task. I notice that the sample rate is 250 Hz by default, and the sample block size is 125 Hz, because it sends data to buffer every half second. So the minimum value for "Stimulus Duration" is 500 ms that is not a good value for a P300 based application! When I try to modify the settings on BCI2000, it comes an error about the fact that it wants to take the automatic settings.
What could I do? Should I work on the firmware?
Please, give me some advices.
I said "because it sends data to buffer every half second" because I read it in this page: https://www.bci2000.org/mediawiki/index.php/Contributions:OpenBCISource
When I try to modify the settings of sample rate and sample block size on BCI2000 I receive an error.
I haven't seen the other forum posts you have mentioned but I will see them soon!
I'm very thankful for your help.
Lisa
Thank you very much for the precious clarifications, I will follow your advices.
I don't know others who had success with BCI2000 spellers. I've only read some studies about OpenVibe, but I will keep you informed about the results of my work.
Lisa
