Ch 1-8 OK, Ch 9-16 Railing?
I was hoping that when I switched from a velcro headset to an Ultracortex3 that my railing issues would end.
Channels 9 through 16 are railed or near railed.
How might I fix this?
In many cases there will also be a second Y-cable allowing for "linked ear" reference. But that is optional. It is however used for many BCI / neurofeedback applications. Linked ear references give a more balanced reference that is not lateralized.
Has the daisy board at any time ever worked correctly, or has it always railed? I see you had some comments on a previous thread,
http://openbci.com/forum/index.php?p=/discussion/430/connecting-electrodes-with-the-fri-19-channel-headband
http://openbci.com/forum/index.php?p=/discussion/254/soldering-16-channel-openbci-kit
I have nearly the same problem. At the beginning of running the board (of 8 channels only), all channels are railing.
Hopefully I did my homework before I posted my note here. I searched thru OpenBCI forum looking for answers. I found this post (or its topic) which is most related to my problem hence I use it. Unfortunately it does not help with finding solution to it.
Setup:
- 16 channel setup – main board + daisy module.
- Connect Main_BIAS to Daisy_BIAS and then connect it to ear 1 (Y cable).
- Connect Main_SRB2 to Daisy_SRB2 and then connect it to the war 2 (Y cable).
- Fix latency to 1mS as per description here: http://docs.openbci.com/tutorials/10-OpenBCI_on_Windows
- Try two different machines: one with Windows 10 and one with Windows XP. Both behave the same way.
- Try two different software’s – Processing and OpenVIBE. Both behave the same way.
Normal operation (8 channels):- When I use my hardware in 8 channel mode (with daisy module attached) everything seems to work fine. I used snapshots of OpenVIBE software to show what is going on. Below is a snapshot with 8-channel system. (Noise is coming from the fact the headset was laying on my desk). Three bottom channels represent accelerometer.
The display used in OpenVIBE was configured as follow:Problem:
or
Observations:
Any ideas here are welcome.
Henryk
So you are saying the screens look similar when using OpenBCI_GUI vs. OpenViBE? OpenBCI_GUI is generally preferred for examples since the lab uses that to checkout hardware.
Your connection of the two Bias leads with the Y-cable is not needed, and may be causing problems. Just use one Bias, for example the lower Bias pin on the mainboard.
Thanks for Your comment.
To answer Your question, yes in general the OpenViBE looks and works
the same as OpenBCI_GUI. The advantage of OpenViBE GUI is control over
time line (can display more data).
Here is what I have done.
Headset on my desk.
All channels are ON.
Headset on my desk.
All channels are OFF.
I noticed that amplitude of the railing is smaller.
I also noticed that periodicity of the railing is more random in such scenario.
Headset on my desk.
Single channel on daisy module is ON.
Railing amplitude slightly increased.
Headset on my desk.
All channel on daisy are ON.
Railing amplitude increased even more.
This time I put Headset on my head.
I configured OpenBCI GUI to work with 8 channels only.
I could notice that from time to time there is an amplitude jump in the main 8 channels.
There is some issue with 3rd channel so for now I turned it off.
Again I put Headset on my head.
This time I configured OpenBCI GUI to work with all 16 channels (except channel 3 which is OFF).
Railing on daisy module is definitely there. It is rather periodic.
I can also notice small disturbance happening on all lines. This one is not a periodic one.
Would this issue might have something to do with power supply or Xtal on main board?
Any thoughts? Any experiemnts to try?
Henryk
Has the daisy module ever worked successfully for you? That is when you first received the kit? It's possible there may be some kind of loose or shorting solder joint in the pins connecting the boards. It's important that the header pins be clean and gold plated where they plug into the sockets. If the pins have solder or flux on them, that can interfere with the reliability of the connector connection.
