cyton and daisy sending only 0 value data
I was placing cytona and daisy in 3d printed box and I start to think I might have damage the boards somehow.
output from my code is now
python3 main2b.py
2024-12-23 23:43:19.165 ( 0.655s) [python3 ] netinterfaces.cpp:91 INFO| netif 'lo' (status: 1, multicast: 0, broadcast: 0)
2024-12-23 23:43:19.165 ( 0.655s) [python3 ] netinterfaces.cpp:91 INFO| netif 'enp3s0' (status: 1, multicast: 4096, broadcast: 2)
2024-12-23 23:43:19.165 ( 0.655s) [python3 ] netinterfaces.cpp:91 INFO| netif 'wlp2s0' (status: 0, multicast: 4096, broadcast: 2)
2024-12-23 23:43:19.165 ( 0.656s) [python3 ] netinterfaces.cpp:91 INFO| netif 'enp3s0' (status: 1, multicast: 4096, broadcast: 2)
2024-12-23 23:43:19.165 ( 0.656s) [python3 ] netinterfaces.cpp:102 INFO| IPv4 addr: c0a832db
2024-12-23 23:43:19.165 ( 0.656s) [python3 ] netinterfaces.cpp:91 INFO| netif 'lo' (status: 1, multicast: 0, broadcast: 0)
2024-12-23 23:43:19.165 ( 0.656s) [python3 ] netinterfaces.cpp:105 INFO| IPv6 addr: fe80::56ee:75ff:fe3f:737c%enp3s0
2024-12-23 23:43:19.165 ( 0.656s) [python3 ] api_config.cpp:270 INFO| Loaded default config
2024-12-23 23:43:19.165 ( 0.656s) [python3 ] common.cpp:65 INFO| git:6ca188c266c21f7228dc67077303fa6abaf2e8be/branch:refs/tags/v1.16.2/build:Release/compiler:GNU-7.5.0/link:SHARED
Starting stream...
+2.792779 +3.876288 +2.570847 +1.797394 +1.588790 +1.138652 +3.425322 +3.565619 +2.294539 +1.729553 +2.008337 +3.567043 +3.494357 +2.575776 +1.131656 +1.694097
+4.162911 +3.555215 +2.398608 +1.704005 +1.688911 +3.707121 +4.196976 +3.558764 +1.287598 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000
+6.771974 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +6.771975 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000
+6.771975 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +6.771976 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000
+6.771976 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +6.771977 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000
+6.771977 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +6.771978 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000 +0.000000
.... and it continues like that.
Cyton diods are all on: red, blue, green and usb dongle is blue with blinking red while data streaming.
But data with 0 only are coming.
Below code used to work and data were changing while I was touching the pins , so it was measuring and sending ok before.
Any suggestion, advice? 2 months work I put into it and now it seems broken.
my test code here:
from pylsl import StreamInfo, StreamOutlet
import serial
import struct
import time
import numpy as np
from scipy import signal
from datetime import datetime
def main():
info = StreamInfo('OpenBCI', 'EEG', 16, 125, 'float32', 'openBCI1234')
outlet = StreamOutlet(info)
port = '/dev/ttyUSB0'
ser = serial.Serial(port=port, baudrate=115200, timeout=1)
print("Starting stream...")
ser.write(b'v')
time.sleep(1)
ser.write(b'b')
try:
while True:
sample_cyton = ser.read(33)
sample_daisy = ser.read(33)
if len(sample_cyton) == 33 and len(sample_daisy) == 33:
data = []
# Cyton (1-8)
for i in range(8):
start = 2 + (i * 3)
value = struct.unpack('>i', b'\0' + sample_cyton[start:start+3])[0]
voltage = value * (4.5 / (2**23 - 1))
data.append(voltage)
# Daisy (9-16)
for i in range(8):
start = 2 + (i * 3)
value = struct.unpack('>i', b'\0' + sample_daisy[start:start+3])[0]
# Wyświetl dane
for value in data:
print(f"{value:+.6f} ", end='')
print()
except KeyboardInterrupt:
print("\nStopping...")
ser.write(b's')
ser.close()
if __name__ == '__main__':
main()
I further checked in with command v and ?
here is output
Connected to /dev/ttyUSB0 at 115200 baud.
Sending 'v' command to check firmware version...
Firmware Version Response:
OpenBCI V3 8-16 channel
On Board ADS1299 Device ID: 0x00
LIS3DH Device ID: 0x00
Firmware: v3.1.1
Sending '?' command to inspect ADS1299 registers...
Register Values Response:
Board ADS Registers
ADS_ID, 00, 00, 0, 0, 0, 0, 0, 0, 0, 0
CONFIG1, 01, 00, 0, 0, 0, 0, 0, 0, 0, 0
CONFIG2, 02, 00, 0, 0, 0, 0, 0, 0, 0, 0
CONFIG3, 03, 00, 0, 0, 0, 0, 0, 0, 0, 0
LOFF, 04, 00, 0, 0, 0, 0, 0, 0, 0, 0
CH1SET, 05, 00, 0, 0, 0, 0, 0, 0, 0, 0
CH2SET, 06, 00, 0, 0, 0, 0, 0, 0, 0, 0
CH3SET, 07, 00, 0, 0, 0, 0, 0, 0, 0, 0
CH4SET, 08, 00, 0, 0, 0, 0, 0, 0, 0, 0
CH5SET, 09, 00, 0, 0, 0, 0, 0, 0, 0, 0
CH6SET, 0A, 00, 0, 0, 0, 0, 0, 0, 0, 0
CH7SET, 0B, 00, 0, 0, 0, 0, 0, 0, 0, 0
CH8SET, 0C, 00, 0, 0, 0, 0, 0, 0, 0, 0
BIAS_SENSP, 0D, 00, 0, 0, 0, 0, 0, 0, 0, 0
BIAS_SENSN, 0E, 00, 0, 0, 0, 0, 0, 0, 0, 0
LOFF_SENSP, 0F, 00, 0, 0, 0, 0, 0, 0, 0, 0
LOFF_SENSN, 10, 00, 0, 0, 0, 0, 0, 0, 0, 0
LOFF_FLIP, 11, 00, 0, 0, 0, 0, 0, 0, 0, 0
LOFF_STATP, 12, 00, 0, 0, 0, 0, 0, 0, 0, 0
LOFF_STATN, 13, 00, 0, 0, 0, 0, 0, 0, 0, 0
GPIO, 14, 00, 0, 0, 0, 0, 0, 0, 0, 0
MISC1, 15, 00, 0, 0, 0, 0, 0, 0, 0, 0
MISC2, 16, 00, 0, 0, 0, 0, 0, 0, 0, 0
CONFIG4, 17, 00, 0, 0, 0, 0, 0, 0, 0, 0
LIS3DH Registers
0x07 00
0x08 00
0x09 00
0x0A 00
0x0B 00
0x0C 00
0x0D 00
0x0E 00
0x0F 00
0x1F 00
0x20 00
0x21 00
0x22 00
0x23 00
0x24 00
0x25 00
0x26 00
0x27 00
0x28 00
0x29 00
0x2A 00
0x2B 00
0x2C 00
0x2D 00
0x2E 00
0x2F 00
0x30 00
0x31 00
0x32 00
0x33 00
0x38 00
0x39 00
0x3A 00
0x3B 00
0x3C 00
0x3D 00
So I decided to give a try to write firmware again (3.1.1) following official guide https://docs.openbci.com/Cyton/CytonProgram/
after ups and downs I managed to load firmware with Arduino IDE, but now my board doesnt recognize commands....
result is
python3 main2c.py
Received unknown character: v
Received unknown character: ?
Hi, there I managed to load firmware 3.1.1 correctly (I had to use windows ) and now I am back to tarting point, so with answer to command ? like that:
python3 main2c.py
Firmware: v3.1.2
Board ADS Registers
LIS3DH Registers
0x07 00
0x08 00
0x09 00
0x0A 00
0x0B 00
0x0C 00
0x0D 00
0x0E 00
0x0F 00
0x1F 00
0x20 00
0x21 00
0x22 00
0x23 00
0x24 00
0x25 00
0x26 00
0x27 00
0x28 00
0x29 00
0x2A 00
0x2B 00
0x2C 00
0x2D 00
0x2E 00
0x2F 00
0x30 00
0x31 00
0x32 00
0x33 00
0x38 00
0x39 00
0x3A 00
0x3B 00
0x3C 00
0x3D 00
I think the problem is
but don't know how to solve it. Can someone help me to understand that? What has possibly happened?
cheers,
Piotr
If you purchased Cyton from OpenBCI and it is not working, send an email to Customer Support: (contact at openbci.com).
If this is the Chinese clone mentioned on another of your threads, then support cannot help you.
Thanks I've already contacted seller from China. Since, this is open source hardware , maybe someone experienced similar issue. I don't expect solution, but maybe a tip what might have happened that I get response ADS1299 Device ID: 0x00
If the LIS and ADS registers are reading out as zeros, it means that the PIC32 microcontroller and those chips are not properly communicating. Something may be shorted or wrong with the SPI bus (MOSI etc lines.) If the Daisy is detachable, try unplugging it. The SPI bus runs between the mainboard and Daisy.
https://en.wikipedia.org/wiki/Serial_Peripheral_Interface
