Cyton data format as seen by BrainFlow
I have a 16-channel setup with Cyton+Daisy+Ultracontex.
I am able to connect and read using the BrainFlow device description .
The data I get seems to be 32 channels of float data. I cannot match this to the Cyton data format definition.
Does anybody know how the data is mapped?
    Best place to ask Brainflow questions is on the Slack. Sign up here,
    https://brainflow.org/
    There may also be some correspondence with this table, see Cyton + Daisy section.
    https://docs.openbci.com/Software/OpenBCISoftware/GUIDocs/#cyton
  • ilnadiilnadi NC, USA
    I already had a Slack account and I asked. Here is the answer in case anybody else looks.
    I ran these checks:
        from brainflow.board_shim import BoardShim, BrainFlowInputParams, BoardIds, BrainFlowPresets
        from pprint import pprint
        # temporary code to learn
        print("\r\nInformation on CYTON")
        pprint(BoardShim.get_board_descr(BoardIds.CYTON_BOARD))
        print("\r\nInformation on CYTON+DAISY")
        pprint(BoardShim.get_board_descr(BoardIds.CYTON_DAISY_BOARD))
    And here is the output
    {'accel_channels': [9, 10, 11],
    'analog_channels': [19, 20, 21],
    'ecg_channels': [1, 2, 3, 4, 5, 6, 7, 8],
    'eeg_channels': [1, 2, 3, 4, 5, 6, 7, 8],
    'eeg_names': 'Fp1,Fp2,C3,C4,P7,P8,O1,O2',
    'emg_channels': [1, 2, 3, 4, 5, 6, 7, 8],
    'eog_channels': [1, 2, 3, 4, 5, 6, 7, 8],
    'marker_channel': 23,
    'name': 'Cyton',
    'num_rows': 24,
    'other_channels': [12, 13, 14, 15, 16, 17, 18],
    'package_num_channel': 0,
    'sampling_rate': 250,
    'timestamp_channel': 22}
    {'accel_channels': [17, 18, 19],
    'analog_channels': [27, 28, 29],
    'ecg_channels': [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16],
    'eeg_channels': [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16],
    'eeg_names': 'Fp1,Fp2,C3,C4,P7,P8,O1,O2,F7,F8,F3,F4,T7,T8,P3,P4',
    'emg_channels': [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16],
    'eog_channels': [1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16],
    'marker_channel': 31,
    'name': 'CytonDaisy',
    'num_rows': 32,
    'other_channels': [20, 21, 22, 23, 24, 25, 26],
    'sampling_rate': 125,
    'timestamp_channel': 30}
