I want to buy a headset. The circumference of my head (measured from about 1 inch above my ears
) is roughly 57.5 cm (22.5”). Will the Med headset (48-58cm) be a good fit? Thanks!
Picking Your Size (Head Circumference)
Be sure to get the right size for your head! Obtain the circumference using a tape measure wrapped horizontally across the widest part of your head.
Small = 42-50cm
Medium = 48-58cm
Large = 58-65cm
The adjustable electrodes allow for overlap in the size range.
So your image above does not appear to be positioned to the 'widest part of your head'.
Hi ByHand, please email to (contact at openbci.com) and confirm you are making the correct choice. Note that on this page,
https://shop.openbci.com/products/ultracortex-mark-iv
It states:
Thanks for replying William. You're right, it is off. Here's a revised image.
