Problems with recording my signals using SD Card to increase sample rate
in OpenBCI_GUI
I bought a 128 GB class 10 Extreme Pro SD Card for recording my signals in order to increase the sample rate to be able to explore another range of frequencies
What happens is that when I try to make my records with 16 channels with the SD card, nothing is recorded.
I don't know what I'm doing wrong, I don't know how to configure openbci
Could you help me to know how it works?
The SDK sample rate changing commands, were only intended to be used with the OpenBCI Wifi Shield. Which is currently not listed in the Shop because some hardware mods are needed. No estimate of if or when this might occur because the OpenBCI staff is busy with Galea development.
The sample rate change commands do not allow faster sample rate recording to SD card.
If your new 128GB card is not working with the normal default sample rate, please advise. Generally it's best to follow the recommendations in the docs,
https://docs.openbci.com/Cyton/CytonSDCard/
