Connecting to Ganglion with Python
coopapap
Montreal
Hi there. I'm looking to connect to my ganglion through python in order to visualize real-time data. Is this possible or do i need a third-party software/package?
The code I have now is found below, though it does not work. COM7 cannot seem to be found, though I can visualize it in my device manager and indeed get the following when I use the command 'mode' in my command prompt:
Status for device COM7:
Baud: 256000
Parity: None
Data Bits: 8
Stop Bits: 1
Timeout: ON
XON/XOFF: OFF
CTS handshaking: OFF
DSR handshaking: OFF
DSR sensitivity: OFF
DTR circuit: OFF
RTS circuit: ON
So I know it is operating. I wonder perhaps if there is a driver that needs to be installed? I've found a cyton driver installation online, but not for the ganglion.
Any information you can provide would be of great benefit. Thank you!
PYTHON CODE -----------------------------------------
import serial
import matplotlib.pyplot as plt
from drawnow import drawnow
import numpy as np
# Initialize variables for data storage
eeg_data = []
# Create a function to update the plot
def plot_data():
plt.plot(eeg_data, 'r-')
# Create a serial connection to the OpenBCI Ganglion
ser = serial.Serial('COM7', 115200) # Use 'COM7' as your serial port
# Main loop for data streaming
while True:
try:
# Read data from the serial port
line = ser.readline().decode('utf-8').strip()
values = line.split(',')
# Assuming the data format is 'timestamp, eeg_data'
if len(values) == 2:
timestamp, eeg_value = values
eeg_data.append(float(eeg_value))
# Limit the number of data points to plot
if len(eeg_data) > 1000:
eeg_data.pop(0)
# Create the real-time plot
plt.clf()
drawnow(plot_data)
except KeyboardInterrupt:
ser.close()
break
# Close the serial connection
ser.close()
You need to use the Brainflow library instead. You cannot read directly from the COM port.
https://brainflow.org/
Okay got it!
Thanks again William
