Cannot run the OpenBCI GUI from the Processing IDE
Liam
China
I followed the tutorial here to run openBCI GUI on processing IDE here:
I'm now stuck in the step that opens openbci file in the sketchbook. The issue is my sketchbook is empty.
I'm using iMac Pro (2017) macOS Big Sur version 11.6.7 along with processing 4.0b8
when I run the file in the folder openbci which was downloaded in the github
it shows following error:
_"A library used by this sketch relies on native code that is not available.
UnsatisfiedLinkError: Unable to load library 'libBoardController.dylib':
dlopen(libBoardController.dylib, 9): image not found
Native library (darwin/libBoardController.dylib) not found in resource path "_
Did it happen with anybody else? I really appreciate it if you could help me on this.
Mentioning Richard @retiutut.
Please use Processing 3.5.4.
