Ganglion Not Starting Data Stream (Windows 10 5.10 GUI, 2.0.1 Firmware)
VeeVee USA
edited June 2022 in Ganglion
Hello!
I've got a Ganglion board I want to tinker around with, but when trying to use the OpenBCI GUI it tells me it can't start the data stream. (It's possible I need to go to BrainFlow forums to ask questions, but figured I'd try here first.)
Error message:
[DEFAULT]: openBCI_GUI: startButton was pressed. Starting data transfer, wait a few seconds.
OpenBCI_GUI: openNewLogFile: opened ODF output file: C:\Users\willi\Documents\OpenBCI_GUI\Recordings\OpenBCISession_2022-06-03_15-50-40\OpenBCI-RAW-2022-06-03_15-50-55.txt
OpenBCI_GUI: BrainFlow Streamer Location: file://C:\Users\willi\Documents\OpenBCI_GUI\Recordings\OpenBCISession_2022-06-03_15-50-40\\BrainFlow-RAW_2022-06-03_15-50-40_0.csv:w
Brainflow start streaming
ERROR: Exception when starting stream
brainflow.BrainFlowError: Error in start_stream:SYNC_TIMEOUT_ERROR
    at brainflow.BoardShim.start_stream(BoardShim.java:711)
    at OpenBCI_GUI$BoardBrainFlow.startStreaming(OpenBCI_GUI.java:2814)
    at OpenBCI_GUI.startRunning(OpenBCI_GUI.java:935)
    at OpenBCI_GUI$TopNav.stopButtonWasPressed(OpenBCI_GUI.java:18462)
    at OpenBCI_GUI$TopNav$2.controlEvent(OpenBCI_GUI.java:18301)
    at controlP5.Controller.callListener(Controller.java:1106)
    at controlP5.Controller.setMousePressed(Controller.java:609)
    at controlP5.ControllerGroup.setMousePressed(ControllerGroup.java:553)
    at controlP5.ControlWindow.mouseReleasedEvent(ControlWindow.java:659)
    at controlP5.ControlWindow.mouseEvent(ControlWindow.java:449)
    at sun.reflect.GeneratedMethodAccessor5.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    at java.lang.reflect.Method.invoke(Method.java:498)
    at processing.core.PApplet$RegisteredMethods.handle(PApplet.java:1432)
    at processing.core.PApplet.handleMethods(PApplet.java:1634)
    at processing.core.PApplet.handleMouseEvent(PApplet.java:2742)
    at processing.core.PApplet.dequeueEvents(PApplet.java:2645)
    at processing.core.PApplet.handleDraw(PApplet.java:2486)
    at processing.opengl.PSurfaceJOGL$DrawListener.display(PSurfaceJOGL.java:866)
    at jogamp.opengl.GLDrawableHelper.displayImpl(GLDrawableHelper.java:692)
    at jogamp.opengl.GLDrawableHelper.display(GLDrawableHelper.java:674)
    at jogamp.opengl.GLAutoDrawableBase$2.run(GLAutoDrawableBase.java:443)
    at jogamp.opengl.GLDrawableHelper.invokeGLImpl(GLDrawableHelper.java:1293)
    at jogamp.opengl.GLDrawableHelper.invokeGL(GLDrawableHelper.java:1147)
    at com.jogamp.newt.opengl.GLWindow.display(GLWindow.java:759)
    at com.jogamp.opengl.util.AWTAnimatorImpl.display(AWTAnimatorImpl.java:81)
    at com.jogamp.opengl.util.AnimatorBase.display(AnimatorBase.java:452)
    at com.jogamp.opengl.util.FPSAnimator$MainTask.run(FPSAnimator.java:178)
    at java.util.TimerThread.mainLoop(Timer.java:555)
    at java.util.TimerThread.run(Timer.java:505)
[ERROR]: Failed to start data stream. Please check hardware. See Console Log or BrainFlow Log for more details.
Setup details and initial diagnostics/testing:
Windows 10, latest GUI (5.1.0 at time of posting), board is running latest Ganglion firmware (2.0.1)
-confirmed running software as administrator
-confirmed board is on the latest firmware
-using a Ganglion Bluetooth dongle
-GUI will detect the board and connect, but upon clicking 'Start Stream', freezes for a few seconds, then displays the above error message in the console
-installed BrainFlow with dependencies (Java) separately just to see if that would help
-read through this discussion: https://openbci.com/forum/index.php?p=/discussion/2736/ganglion-ota-programming-for-windows-new-instructions
What I haven't done yet but might do:
-reload the Ganglion firmware; the board is from the Kickstarter days and I managed to get it hardware-programmed for OTA updates but it's possible I goofed on that somewhere and need to reflash it - the unit shows 2.0.1 for the software revision string, so I think it should be fine
Any help would be appreciated; I'm thinking I'm missing something but not sure.
Thank you! -Vee
