Filtering ECG raw data
Dear all, thi message for a comparison with you regarding ECG data filtering. By applying a 5 -50 Hz passband (as seen in the OpenBCI GUI) to ECG raw data saved by Cyton, the corresponding plots do not correspond with those seen during acquisition in the GUI. Maybe I am missing something, just as detial, I am plotting using IGOR and applying a low pass filter at 5Hz e and an high pass filter at 50 Hz. Does anybody experienced something like this? Thank you.
    Giuseppe, hi.
    You have the filter sense inverted. You want high pass at 5 and low pass at 50. Alternately, and preferable, just use a simple BANDPASS from 5 to 50.
  • Dear William, thank you ! I solved, just a mistake in setting the filter on Igor....now I was able to plot the ECG correctly, they seem very similar to what I see on the OpenBCI GUI. Lastly, the unit of mesaure on the Y axis, do I need to convert them? or do they represent Vrms dirctly? Best, Giuseppe
    edited May 14
    The sample units are microvolts. The GUI shows uVrms as just an indication of average amplitude. Samples have no RMS averaging / smoothing.
    https://en.wikipedia.org/wiki/Root_mean_square
  • abummu1abummu1 Malaysia
    @giuseppetx1
    Pls, can you help me with the code for the filters?
    Thanks in advance
  • Dear, I use a software for plotting and data analysis, IgorPro, it provides a user interface for the filters setting, showing the resulting pass band, the important this is you set the sampling 250 Hz, just to explain see the screenshot in attachment. I know that other software like Origin Pro can provide the same functionalities. Sorry but I am not programming by coding ....
    Giuseppe
    @abummu1 said:
    @giuseppetx1!
    Thanks in advance
    @giuseppetx1
    Thanks for the response.
    @giuseppetx1
    Pls, how did you insert raw ECG data into the IGOR since it is in a text file? Was it a direct plot or there is a menu for uploading? Thank you for your time
  • Igor can in general read .txt file, but with the openbci raw data I found many problems in importing settings, so the fastest way I am finally using is to organize the columns in a file excel and import that file .xls with Igor, so that the columns are already ordered with the openbci channels, ready to be filtered and plotted.
    @abummu1 said:
    @giuseppetx1
    @giuseppetx1
    That's awesome. Thanks for the tips
