CSV Raw Data Output Directory & SD Card
in OpenBCI_GUI
Good Morning All,
I'm trying to locate the directory to which the raw output file is saved - the documentation says it is in the same directory as the GUI however I do not see it. Is there a direct path? Does it need to be set up in advance? Lastly, how might this process change when an SD card is used for storage?
I appreciate the information.
Best,
Carissa
+(for context, I am using Cyton+Daisy, without WIFI Shield).
https://docs.openbci.com/docs/06Software/01-OpenBCISoftware/GUIDocs#data-log-options
Thank you Retiutut
