GUI v5.0.2 Now Available!
v5.0.2 - "The UI Update"
https://github.com/OpenBCI/OpenBCI_GUI/releases/tag/v5.0.2
https://openbci.com/downloads
Improvements
- Improved Cyton Auto-Connect button w/ Auto-Scan
- Update Hardware Settings UI for ADS1299 boards
- Highlight channels in Hardware Settings that are out of sync with board
- Require users to send or revert Hardware Settings before closing UI
- Add "Send" button to Hardware Settings
- Update SessionData UI in Control Panel
- Update ChannelSelect Feature in Widget Class to show what channels are on or off
- Improve Time Series y-axis autoscale performance
- Add channel select feature to FFT widget
- Remove configurable gain behaviour and default to dynamic gain scaler
Bug Fixes
- Exit session init when current board fails to initialize
- Fix drawing error on lower resolution screens #900
- Save BDF start time in 24hr format instead of 12hr #904
- Fix TimeSeries Unfiltered Networking Output #891 #889
- Fix TimeSeries Networking Output when using Playback Mode w/ GUI or SD file #906
- Let users know when Cyton Auto-Scan is happening with an overlay
- Refactor GUI Buttons and ButtonHelpText
Notable changes from the above list:
- Updated Cyton Auto-Connect button - "one click, that's it!"
- Fix screen resolution issue on lower resolution screens
- GUI 5.0.2 is also known as "The UI Update". Large sections of the GUI have been refactored to minimize bugs and make it easier to modify the GUI for future changes.
