is Cyton LSL stream typical EEG signal representation?
I am using cyton board with 8 channel and the open bci gui version in 5.0.2. when i read the lsl stream and plot the channel data it consist signal wave like periodic sign wave. I didn't enable filters given by GUI for get raw eeg signals(time series). I used python pylsl library for acquire data and below is my code.
the framerate is given as 250Hz and for each iteration get 8 channel data
when i plot my channel data it is plotted like below, and it does not feel like raw eeg data.
what can be the issue here?
Prageethda, hi.
Raw Cyton data has a DC offset. This is easily removed with your own high pass or bandpass filter.
So if you had just pre-filtered with the GUI settings, that would be another way to go.
@wjcroft hi.
I applied filtered of GUI settings and turn on the filter on LSL settings. But still i got the same signal. What can be the reason.? Is it a bug in GUI?
