OpenBCI with OpenVibe
Hi ,
I need to complete P300test. I have Ultracortex mark IV headset and by OPenBCI Gui, I could run cyton board successfully. But when I want to interface with OpenVIbe v 2.2, it didn't connect. Like: It not showing the COM3 port on Openvibe. It means, it can't detect Dongle port. Can you give me some outline ? Operating system is W10.
[ INF ] OpenBCI: Status - ** NO ** Daisy module
option enabled, 11 channels -- 8 EEG and 3 accelerometer -- at 250Hz.
[ INF ] Connecting to device [OpenBCI]...
[ INF ] OpenBCI: Configured 'missing sample delay
before reset' to 1000 ; this can be changed in the openvibe configuration file
setting the AcquisitionDriver_OpenBCI_MissingSampleDelayBeforeReset token
[ INF ] OpenBCI: Configured 'dropped sample count
before reset' to 5 ; this can be changed in the openvibe configuration file
setting the AcquisitionDriver_OpenBCI_DroppedSampleSafetyDelayBeforeReset token
[ INF ] OpenBCI: Configured 'dropped sample safety
delay before reset' to 1000 ; this can be changed in the openvibe configuration
file setting the AcquisitionDriver_OpenBCI_DroppedSampleSafetyDelayBeforeReset
token
[ ERROR ] OpenBCI: Port has not been configure and driver
could not open any port
[ ERROR ] Connection failed...
[ INF ] Disconnecting.
How can I see the plot of average ERP IN p300 test ?
I want to use two Beep box in "erp-2-record-signal .xml" . One for short beep another for long beep . How can I change the beep tone ? I also written on "Openvibe "forum.
Rafia
