csv Raw Data Processing PLOT
rd0804
OC
in OpenBCI_GUI
What type of DSP the raw data in the cvs files undergoes to make the plot in Matlab look like the one you get in “Processing”?
- High Pass Filter = 0.5Hz to remove the DC Offset
- Notch Filter @ 60Hz to remove the AC line noise
- Band Pass Filtering = 7Hz - 13Hz, etc. ...
And last, if the vertical scale in the "Processing" plot is set to 200uV, is this from -100uV to +100uV? or from -200uV to +200uV?
Thank you
