Signal quality difference between Cyton and Ganglion
I'm working on a project to read EEG and get the band powers, specifically Alpha and Beta. I've been using a Ganglion, but have been having very noisy signals. I switched to a Cyton I had for a previous project and had much much cleaner signals. Here's my setup: I have four electrodes across the forehead (AF7, Fp1, Fp2, AF8), and two earclip electrodes.
On the Ganglion, the four electrodes are connected to the +1 ... +4 pins and the earclips are attached to D_G and REF. When holding absolutely still, I'm getting around 100µV on average. The channel switches are set off, so the channels will use the reference pin, and not the corresponding -1 ... -4 pins.
Immediately after, I moved the electrodes to the Cyton board. Here, the four electrodes are connected to the 1P ... 4P pins and the earclips are attached to BIAS and SRB pins. When connected, I set the SRB1 to "Yes" for the first four channels in the "Hardware Settings" menu. Now, I'm getting around 3.5µV on average.
So my question is why is the Cyton board so much better than the Ganglion? Am I wiring things up correctly?
-Pete
