Board disconnecting all the time...
I just bought a ganglion board, for artistic purpose.
I just tested it yesterday, and i have a big issue. The board work, i have data in the GUY, and the board connects with BLE propely. But each time, after 30sec-5mn, the board disconnects from itself, the led starts blinking, and i have to restart the software each time...
I tried many things, such as moving the board just next to the bluetooth receiver, or this kind of stuff... I wanted maybe to update the board, but the version seems okay : ( Firmware Revision String 1.1.0 and Software revision string 1.1.2)
Other thing that is strange too, when i configure the data source in the GUI, I have to select "BDF+" instead of "OpenBCI" because if i do so, it will freeze when i click "START SYSTEM"...
I'm a little bit lost, and this problem is really ennoying. I hope that it is a knowned issue for you, and that you have the solution...
Sincerely yours,
J-d
Sincerely yours,
J-d
That is a very annoying problem! What operating system are you running? Which GUI version? Have you considered updating your firmware to the latest?
This also sounds like a possible battery issue, in regards to the disconnecting.
I'm pretty sure this is not a normal problem so something is up!
The latest firmware is 2.0.0
https://github.com/OpenBCI/OpenBCI_Ganglion_Library/releases
The tutorial for uploading firmware
http://docs.openbci.com/Hardware/09-Ganglion_Programming_Tutorial
