OpenBCI_NodeJS_Ganglion: cannot get accelData from sample (undefined)
NikoKoroNikoKoro Athens, Greece
edited March 2017 in Ganglion
Hello! I'm using the Node.js library for the ganglion board but when I receive the data from the board, the sample.accelData value is undefined.
Below is the code I'm using(image):
And here is the output that I get(image again):
As far as I know, the accelerometer is enabled by default, but I tried to enable it again (with .accelStart() ) and nothing changed.
Also, when I use the .on('accelerometer') function, the code inside is never executed.
I'm pretty sure I'm doing something wrong, but can't figure out what so far.
Thanks in advance!
    Mentioning AJ @pushtheworld
    The accelerometer is not enabled by default. You need to send the Ganglion the accelerometer enable command.
  • NikoKoroNikoKoro Athens, Greece
    edited March 2017
    Hello! I was trying to use the .accelStart() command, but I just get a "pending" promise. Also, the documentation for the NodeJS library mentions that the accelerometer is enabled by default.
    Below are the images of my code and output:
    Should I put the accelerometer enable command somewhere else?
    Thanks for the reply!
  • @NikoKoro this sounds super frustrating!
    Sorry this is happening to you, I wonder if this is related to open issue 27 https://github.com/OpenBCI/OpenBCI_NodeJS_Ganglion/issues/27
    Could you please copy and paste your code over onto that GitHub issue?
    I am digging into this right now!
    Sure I'll do it right away. Thanks!
